Hugging Face to S3 required parameters
When deploying the Hugging Face to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Hugging Face to S3 ReadyFlow configuration parameters
Parameter Name Description
AWS Access Key ID Specify the AWS access key ID.
AWS Secret Access Key Specify the AWS secret access key.
Dataset Name Specify the Dataset name. The default is Salesforce/wikitext.
Destination S3 Bucket Specify the name of the destination S3 bucket you want to write to.
Destination S3 Path Specify the path within the destination bucket where you want to write to.
Destination S3 Region Specify the AWS region in which your destination bucket was created.
