JDBC to S3 required parameters
When deploying the JDBC to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. JDBC to S3 ReadyFlow configuration parameters
Parameter Name Description
AWS Access Key ID Specify the AWS access key ID.
AWS Secret Access Key Specify the AWS secret access key.
CSV Delimiter If your output data is CSV, specify the delimiter here. The default value is ,.
Data Output Format Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow.
Database Connection URL Specify the JDBC database connection URL used to connect to your source database. May contain database system name, host, port, database name and some parameters. The exact syntax of a database connection URL is specified by your DBMS, for example, jdbc:mysql://hostname:port/database for MySQL databases.
Database Driver Upload the database driver jar file for your source database.
Database Driver Class Name Specify the source database driver class name. For example, com.mysql.jdbc.Driver for MySQL databases.
Database Incremental Fetch Column Specify the column that should be used to track state as new data lands in the source table.
Database Password Specify the source database password.
Database Table Name Specify the source database table name.
Database User Specify the source database user.
Destination S3 Bucket Specify the name of the destination S3 bucket you want to write to.
Destination S3 Path Specify the path within the destination bucket where you want to write to.
Destination S3 Region Specify the AWS region in which your destination bucket was created.
Filter Rule Specify the filter rule expressed in SQL to filter database records. Records matching the filter are written to the destination. The default value forwards all records.
