Kafka to ADLS Avro required parameters
When deploying the Kafka to ADLS Avro ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Kafka to ADLS Avro ReadyFlow configuration parameters
Parameter Name Description
AWS Access Key ID Specify the AWS access key ID.
AWS Region Specify the AWS region in which your schema was created.
AWS Secret Access Key Specify the AWS secret access key.
CSV Delimiter If your source data is CSV, specify the delimiter here. The default value is ,.
Data Input Format Specify the format of your input data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow.
Destination ADLS File System Specify the name of the destination ADLS file system also known as container.
Destination ADLS Path Specify the path within the destination container where you want to write to.
Destination ADLS Storage Account Key Specify the destination ADLS storage account key.
Destination ADLS Storage Account Name Specify the destination ADLS storage account name.
Kafka Broker Endpoint Specify the Kafka bootstrap servers string as a comma separated list.
Kafka Consumer Group ID Specify the id for the consumer group used for the source topic you are consuming from.
Kafka Source Topic Specify the topic you want to read from.
SASL Password Specify the password to access your Kafka cluster via SASL/SCRAM authentication.
SASL Username Specify the username to access your Kafka cluster via SASL/SCRAM authentication.
Schema Name Specify the schema name to be looked up in the Schema Registry for the source Kafka topic.
Schema Registry Name Specify the name of the Schema Registry you want to connect to.
