ReadyFlow overview: Kafka Filter to Kafka
You can use the Kafka Filter to Kafka ReadyFlow to consume JSON, CSV, or Avro events from a Kafka topic, filter them, and write them to a destination Kafka topic.
This ReadyFlow consumes JSON, CSV, or Avro data from a source Kafka topic and parses the schema by looking up the schema name in a Schema Registry. You can filter events by specifying a SQL query in the Filter Rule parameter. The filtered events are then converted to the specified output data format and written to the destination Kafka topic. Failed Kafka write operations are retried automatically to handle transient issues. Define a KPI on the failure_WriteToKafka connection to monitor failed write operations.
Kafka Filter to Kafka ReadyFlow details
Source Kafka Topic
Source Format JSON, CSV, Avro
Destination Kafka Topic
Destination Format JSON, CSV, Avro
