Kafka Filter to Kafka required parameters
When deploying the Kafka Filter to Kafka ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Region | Specify the AWS region in which your schema was created. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| CSV Delimiter | If your source data is CSV, specify the delimiter here. The default value is
| Data Input Format | Specify the format of your input data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Data Output Format | Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Filter Rule | Specify the filter rule expressed in SQL to filter streaming events for the destination topic. Records matching the filter are written to the destination topic. The default value forwards all records. |
| Kafka Broker Endpoint | Specify the Kafka bootstrap servers string as a comma separated list. |
| Kafka Consumer Group ID | Specify the id for the consumer group used for the source topic you are consuming from. |
| Kafka Destination Topic | Specify the destination topic name. |
| Kafka Source Topic | Specify the topic you want to read from. |
| SASL Password | Specify the password to access your Kafka cluster via SASL/SCRAM authentication. |
| SASL Username | Specify the username to access your Kafka cluster via SASL/SCRAM authentication. |
| Schema Name | Specify the schema name to be looked up in the Schema Registry. |
| Schema Registry Name | Specify the name of the Schema Registry you want to connect to. |
