Kafka to Kafka required parameters
When deploying the Kafka to Kafka ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| Kafka Broker Endpoint | Specify the Kafka bootstrap servers string as a comma separated list. |
| Kafka Consumer Group ID | Specify the id for the consumer group used for the source topic you are consuming from. |
| Kafka Destination Topic | Specify the destination topic name. |
| Kafka Source Topic | Specify the topic you want to read from. |
| SASL Password | Specify the password to access your Kafka cluster via SASL/SCRAM authentication. |
| SASL Username | Specify the username to access your Kafka cluster via SASL/SCRAM authentication. |
