Kafka to S3 Avro required parameters
When deploying the Kafka to S3 Avro ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Region | Specify the AWS region in which your destination bucket and schema was created. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| CSV Delimiter | If your source data is CSV, specify the delimiter here. The default value is
| Data Input Format | Specify the format of your input data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination S3 Bucket | Specify the name of the destination S3 bucket you want to write to. |
| Destination S3 Path | Specify the path within the destination bucket where you want to write to. |
| Kafka Broker Endpoint | Specify the Kafka bootstrap servers string as a comma separated list. |
| Kafka Consumer Group ID | Specify the id for the consumer group used for the source topic you are consuming from. |
| Kafka Source Topic | Specify the topic you want to read from. |
| SASL Password | Specify the password to access your Kafka cluster via SASL/SCRAM authentication. |
| SASL Username | Specify the username to access your Kafka cluster via SASL/SCRAM authentication. |
| Schema Name | Specify the schema name to be looked up in the Schema Registry. |
| Schema Registry Name | Specify the name of the Schema Registry you want to connect to. |
