S3 to ADLS required parameters
When deploying the S3 to ADLS ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. S3 to ADLS ReadyFlow configuration parameters
Parameter Name Description
Destination ADLS File System Specify the name of the destination ADLS file system also known as container.
Destination ADLS Path Specify the path within the destination container where you want to write to.
Destination ADLS Storage Account Key Specify the destination ADLS storage account key.
Destination ADLS Storage Account Name Specify the destination ADLS storage account name.
Preserve S3 Prefix Specify whether to preserve or ignore the folder hierarchy of the source files. Set to TRUE to preserve folder hierarchy in the destination path. Set to FALSE to flatten the hierarchy and only keep the file in the destination path.
Source S3 Access Key ID Specify the source S3 access key ID.
Source S3 Bucket Specify the name of the source S3 bucket you want to read from.
Source S3 Path Specify the path within the source bucket where you want to read files from.
Source S3 Region Specify the AWS region in which your source bucket was created.
Source S3 Secret Access Key Specify the source S3 secret access key.
