S3 to Milvus required parameters
When deploying the S3 to Milvus ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| HuggingFace Embedding Model | Specify the HuggingFace model name to use for embedding the data. The default model is 'all-MiniLM-L12-v2'. |
| Milvus Access Token | Specify the access token for the destination Milvus instance. |
| Milvus Collection Name | Specify the name of the destination Milvus collection. |
| Milvus Instance URI | Specify the URI of the destination Milvus instance. |
| Source S3 Access Key ID | Specify the source S3 access key ID. |
| Source S3 Bucket | Specify the name of the source S3 bucket you want to read from. |
| Source S3 Path | Specify the path within the source bucket where you want to read files from. |
| Source S3 Region | Specify the AWS region in which your source bucket was created. |
| Source S3 Secret Access Key | Specify the source S3 secret access key. |
