S3 to OpenSearch required parameters
When deploying the S3 to OpenSearch ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| OpenAI API Key | Specify the API key used to authenticate to OpenAI. |
| OpenAI Model | Specify the OpenAI model name to use for embedding the data. The default model is 'text-embedding-ada-002'. |
| OpenSearch Document Text Field | The name of the field in the OpenSearch document where the text is stored. The default value is `text`. |
| OpenSearch Document Vector Field | Specify the name of the field in the OpenSearch document where the embeddings are stored. This field needs to be a 'knn_vector' type. The default value is `vector_embedding`. |
| OpenSearch Host URL | Specify the URL of the destination OpenSearch instance. |
| OpenSearch Index | Specify the name of the destination OpenSearch index. |
| OpenSearch Password | Specify the password to use for authenticating to the OpenSearch server. |
| OpenSearch Username | Specify the username to use for authenticating to the OpenSearch server. |
| Source S3 Access Key ID | Specify the source S3 access key ID. |
| Source S3 Bucket | Specify the name of the source S3 bucket you want to read from. |
| Source S3 Path | Specify the path within the source bucket where you want to read files from. |
| Source S3 Region | Specify the AWS region in which your source bucket was created. |
| Source S3 Secret Access Key | Specify the source S3 secret access key. |
