S3 to Pinecone required parameters
When deploying the S3 to Pinecone ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. S3 to Pinecone ReadyFlow configuration parameters
Parameter Name Description
OpenAI API Key Specify the API key used to authenticate to OpenAI.
OpenAI Model Specify the OpenAI model name to use for embedding the data.
The default model is 'text-embedding-ada-002'.
Pinecone API Key Specify the API key used to authenticate to Pinecone.
Pinecone Environment Specify the name of the Pinecone environment.
Pinecone no longer requires the environment to connect, but you still need to provide a value for this parameter for the deployment to succeed as the related property in the Pinecone processor is required.
Pinecone Index Specify the name of the Pinecone index.
To ensure correct functionality of this ReadyFlow, make sure your Pinecone index has been created with the same dimension as the 'text-embedding-ada-002' model (1536).
Source S3 Access Key ID Specify the source S3 access key ID.
Source S3 Bucket Specify the name of the source S3 bucket you want to read from.
The full path is constructed from:
s3a://#{Source S3 Bucket}/#{Source S3 Path}
Source S3 Path Specify the path within the source bucket where you want to read files from.
Source S3 Region Specify the AWS region in which your source bucket was created.
Source S3 Secret Access Key Specify the source S3 secret access key.
