S3 to Qdrant required parameters
When deploying the S3 to Qdrant ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| OpenAI API Key | Specify the API key used to authenticate to OpenAI. |
| OpenAI Model | Specify the OpenAI model name to use for embedding the data. The default model is 'text-embedding-ada-002'. |
| Qdrant API Key | Specify the API key used to authenticate to Qdrant. |
| Qdrant Collection | Specify the name of the destination Qdrant collection. |
| Qdrant URL | Specify the URL of the destination Qdrant instance. |
| Source S3 Access Key ID | Specify the source S3 access key ID. |
| Source S3 Bucket | Specify the name of the source S3 bucket you want to read from. The full path is constructed from: s3a://#{Source S3 Bucket}/#{Source S3 Path} |
| Source S3 Path | Specify the path within the source bucket where you want to read files from. The full path is constructed from: s3a://#{Source S3 Bucket}/#{Source S3
Path} |
| Source S3 Region | Specify the AWS region in which your source bucket was created. |
| Source S3 Secret Access Key | Specify the source S3 secret access key. |
