S3 to S3 Avro required parameters
When deploying the S3 to S3 Avro ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Region | Specify the AWS region in which your sorce bucket, destination bucket and schema was created. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| CSV Delimiter | If your source data is CSV, specify the delimiter here. The default value is
| Data Input Format | Specify the format of your input data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination S3 Bucket | Specify the name of the destination S3 bucket you want to write to. |
| Destination S3 Path | Specify the path within the destination bucket where you want to write to. |
| Preserve S3 Prefix | Specify whether to preserve or ignore the folder hierarchy of the source files. Set to
TRUE to preserve folder hierarchy in the destination path. Set to
FALSE to flatten the hierarchy and only keep the file in the destination
path. |
| Schema Name | Specify the schema name to be looked up in the Schema Registry. |
| Schema Registry Name | Specify the name of the Schema Registry you want to connect to. |
| Source S3 Bucket | Specify the name of the source S3 bucket you want to read from. |
| Source S3 Path | Specify the path within the source bucket where you want to read files from. |
