S3 to S3 required parameters
When deploying the S3 to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| Destination S3 Access Key ID | Specify the destination S3 access key ID. |
| Destination S3 Bucket | Specify the name of the destination S3 bucket you want to write to. |
| Destination S3 Path | Specify the path within the destination bucket where you want to write to. |
| Destination S3 Region | Specify the AWS region in which your destination bucket was created. |
| Destination S3 Secret Access Key | Specify the destination S3 secret access key. |
| Preserve S3 Prefix | Specify whether to preserve or ignore the folder hierarchy of the source files. Set to
TRUE to preserve folder hierarchy in the destination path. Set to
FALSE to flatten the hierarchy and only keep the file in the destination
path. |
| Source S3 Access Key ID | Specify the source S3 access key ID. |
| Source S3 Bucket | Specify the name of the source S3 bucket you want to read from. |
| Source S3 Path | Specify the path within the source bucket where you want to read files from. |
| Source S3 Region | Specify the AWS region in which your source bucket was created. |
| Source S3 Secret Access Key | Specify the source S3 secret access key. |
