S3 to IBM watsonx required parameters
When deploying the S3 to IBM watsonx ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| Destination S3 Bucket | Specify the name of the destination S3 bucket you want to write to. |
| Destination S3 Path | Specify the path within the destination bucket where you want to write to. |
| Destination S3 Region | Specify the AWS region in which your destination bucket was created. |
| IBM Cloud API Key | Specify the IBM Cloud API Key needed for the IAM token request. |
| IBM watsonx Model Input | Specify the model input body in JSON format. Specify a valid (not deprecated) IBM watsonx model and your IBM project ID. Do not modify the |
| IBM watsonx Model URL | Specify the IBM watsonx model URL. The default value is
https://us-south.ml.cloud.ibm.com/ml/v1/text/generation?version=2023-05-29. |
| Source S3 Bucket | Specify the name of the source S3 bucket you want to read from. |
| Source S3 Path | Specify the path within the source bucket where you want to read files from. |
| Source S3 Region | Specify the AWS region in which your source bucket was created. |
