Salesforce filter to ADLS required parameters
When deploying the Salesforce filter to ADLS ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| Age Field | Specify the name of a TIMESTAMP field that will be used to filter records using a
bounded time window. The QuerySalesforceObject processor will return only those records with
a timestamp value newer than the timestamp recorded after the last processor run. The default
value is |
| CSV Delimiter | If your output data is CSV, specify the delimiter here. The default value is
| Data Output Format | Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination ADLS File System | Specify the name of the destination ADLS file system also known as container. |
| Destination ADLS Path | Specify the path within the destination container where you want to write to. |
| Destination ADLS Storage Account Key | Specify the destination ADLS storage account key. |
| Destination ADLS Storage Account Name | Specify the destination ADLS storage account name. |
| Filter Rule | Specify the filter rule expressed in SQL to filter events for the destination object store. Records matching the filter will be written to the destination object store. The default value forwards all records. |
| Salesforce Consumer Key | Specify your Salesforce consumer key. |
| Salesforce Consumer Secret | Specify your Salesforce consumer secret. |
| Salesforce Domain Name | Specify your Salesforce domain name. |
| Salesforce Field Names | Specify the field names requested from the sObject to be queried as a comma separated list. |
| Salesforce Password and Security Token | Specify your Salesforce password concatenated with your Salesforce security token. |
| Salesforce sObject Name | Specify the Salesforce sObject to be queried. |
| Salesforce Username | Specify your Salesforce username. |
