Salesforce filter to S3 required parameters
When deploying the Salesforce filter to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| Age Field | Specify the name of a TIMESTAMP field that will be used to filter records using a
bounded time window. The QuerySalesforceObject processor will return only those records with
a timestamp value newer than the timestamp recorded after the last processor run. The default
value is |
| AWS Access Key ID | Specify the AWS access key ID. |
| AWS Secret Access Key | Specify the AWS secret access key. |
| CSV Delimiter | If your source data is CSV, specify the delimiter here. The default value is
| Data Output Format | Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow. |
| Destination S3 Bucket | Specify the name of the destination S3 bucket you want to write to. |
| Destination S3 Path | Specify the path within the destination bucket where you want to write to. |
| Destination S3 Region | Specify the AWS region in which your destination bucket was created. |
| Filter Rule | Specify the filter rule expressed in SQL to filter events for the destination object store. Records matching the filter will be written to the destination object store. The default value forwards all records. |
| Salesforce Consumer Key | Specify your Salesforce consumer key. |
| Salesforce Consumer Secret | Specify your Salesforce consumer secret. |
| Salesforce Domain Name | Specify your Salesforce domain name. |
| Salesforce Field Names | Specify the field names requested from the sObject to be queried as a comma separated list. |
| Salesforce Password and Security Token | Specify your Salesforce password concatenated with your Salesforce security token. |
| Salesforce sObject Name | Specify the Salesforce sObject to be queried. |
| Salesforce Username | Specify your Salesforce username. |
