Shopify to S3 required parameters
When deploying the Shopify to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Shopify to S3 ReadyFlow configuration parameters
Parameter Name Description
AWS Access Key ID Specify the AWS access key ID.
AWS Secret Access Key Specify the AWS secret access key.
CSV Delimiter If your output data is CSV, specify the delimiter here. The default value is ,.
Data Output Format Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow.
Destination S3 Bucket Specify the name of the destination S3 bucket you want to write to.
Destination S3 Path Specify the path within the destination bucket where you want to write to.
Destination S3 Region Specify the AWS region in which your destination bucket was created.
Incremental Delay Specify a value for this Shopify processor property to avoid missing objects when the clocks of your local machines and Shopify servers are not in sync. This property is only used if Incremental Loading is set to true.
The default value is 3 sec.
Incremental Loading Specify a value for this Shopify processor property to decide whether to load queried objects incrementally. Set to true to query each object exactly once. Set to false to query each object at least once.
The default value is true.
Shopify Access Token Specify the Shopify access token to authenticate requests.
Shopify Object Category Specify the Shopify object category to request.
The following values are supported:
  • CUSTOMERS
  • DISCOUNTS
  • INVENTORY
  • ONLINE_STORE
  • ORDERS
  • PRODUCTS
  • SALES_CHANNEL
  • STORE_PROPERTIES
Shopify Object Type
Specify the Shopify object type (subcategory) to request.
The Object Type depends on the Object Category and the following (category: types) groups are supported:
  • CUSTOMERS: customers;
  • DISCOUNTS: price_rules;
  • INVENTORY: locations;
  • ONLINE_STORE: blogs, comments, pages, redirects, script_tags, themes;
  • ORDERS: checkouts, draft_orders, orders;
  • PRODUCTS: collects, custom_collections, products, custom_collections;
  • SALES_CHANNEL: collection_listings, product_listings;
  • STORE_PROPERTIES: countries, currencies, policies, shipping_zones;
Shopify Result Limit Specify the maximum number of results returned by Shopify.
The default value is 100.
Shopify Store Domain Specify the domain of the Shopify store. For example, nifistore.myshopify.com.
