Slack to Milvus required parameters
When deploying the Slack to Milvus ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| HuggingFace Embedding Model | Specify the HuggingFace model name to use for embedding the data. The default model is 'all-MiniLM-L12-v2'. |
| Milvus Access Token | Specify the access token for the destination Milvus instance. |
| Milvus Collection Name | Specify the name of the destination Milvus collection. |
| Milvus Instance URI | Specify the URI of the destination Milvus instance. |
| Slack Channel ID | Specify the Slack channel ID. |
| Slack User or Bot Access Token | Specify the Slack user or bot access token. |
