Slack to Pinecone required parameters
When deploying the Slack to Pinecone ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
| OpenAI API Key | Specify the API key used to authenticate to OpenAI. |
| Pinecone API Key | Specify the API key used to authenticate to Pinecone. |
| Pinecone Environment | Specify the name of the Pinecone environment. Pinecone no longer requires the environment to connect, but you still need to provide a value for this parameter for the deployment to succeed as the related property in the Pinecone processor is required. |
| Pinecone Index | Specify the name of the Pinecone index. To ensure correct functionality of this ReadyFlow, make sure your Pinecone index has been created with the same dimension as the 'text-embedding-ada-002' model (1536). |
| Slack Channel ID | Specify the Slack channel ID. |
| Slack User or Bot Access Token | Specify the Slack user or bot access token. |
