Debugging using Trino Web UI
You can use the Trino Web UI to view information about running or completed queries, configuration settings, details about resource usage, and performance of your .
  1. Log in to the instance.
  2. In the Overview page, click the Trino Web UI.
    The CLUSTER OVERVIEW page is displayed.
You can view the cluster metrics and query details to monitor your instance.
