Default connectors in Cloudera Lakehouse Engine
Cloudera Lakehouse Engine creates default connectors during deployment that connect the Trino engine to Cloudera Harmony Catalog and, optionally, to the Hive Metastore of a Cloudera Base cluster.
Default connectors are ready to use after deployment, and you can run queries through them without creating a connector. Depending on whether you configure the Cloudera Base Connector during deployment, your Cloudera Lakehouse Engine instance has one or three default connectors. You can view them on the Connectors tab of the instance page.
Table 1. Default connectors
Connector name Type Data source Availability
harmonycatalog iceberg Cloudera Harmony Catalog Created in every deployment
hive-base hive Hive Metastore (HMS) of the Cloudera Base cluster Created only when you configure the Cloudera Base Connector during deployment
iceberg-base iceberg HMS of the Cloudera Base cluster Created only when you configure the Cloudera Base Connector during deployment
You can modify a default connector, but you cannot delete the default connector.
Cloudera Harmony Catalog connector
Cloudera Lakehouse Engine connects to Cloudera Harmony Catalog by default. Every Cloudera Lakehouse Engine instance has an Iceberg connector that uses the Cloudera Harmony Catalog instance, powered by Apache Polaris, as its data source. The default table format of this connector is Apache Iceberg V3.
The connector name is the same as the catalog name that you select for Cloudera Harmony Catalog during the deployment. The default catalog name is harmonycatalog, so the connector is displayed as harmonycatalog on the Connectors tab.
You do not need to configure the connector. Before users can query Cloudera Harmony Catalog tables, you must grant the Trino engine access to the realm, catalogs, namespaces, and tables in Cloudera Harmony Catalog. For more information, see Granting Cloudera Lakehouse Engine access to Cloudera Harmony Catalog.
Cloudera Base connectors
The Cloudera Base Connector provides a secure connection between Data Services and an existing Cloudera Base cluster. It connects to Cloudera Base 7.1.9 and 7.3.2 clusters, and carries the Hive and Impala policies configured on the Base cluster HMS, which simplifies migration to Anywhere Cloud and Cloudera Lakehouse Engine.
The Cloudera Base Connector is optional. You configure it during deployment, in the Required Engine Configuration section, by selecting Reuse Existing Instance or Provision New Instance and entering the Cloudera Manager connection details. For more information, see Deploying Cloudera Lakehouse Engine on Anywhere Cloud.
When you configure the Cloudera Base Connector, Cloudera Lakehouse Engine creates the hive-base and iceberg-base connectors. These connectors are configured to work with the data in the HMS of the Cloudera Base cluster. You do not need to set secrets or configure these connectors manually.
The hive-base and iceberg-base connectors have the following default behavior:
  • Table redirection – Table redirection between the hive-base and iceberg-base connectors is not enabled by default. You can enable table redirection manually.
    Before you enable table redirection, review the following limitations:
    • Table redirection applies to tables only. Views are not redirected.
    • Some Apache Ranger policies are not applied correctly when table redirection is enabled.
