Deleting secrets associated with connectors
Learn how you can delete secrets that are no longer required to be associated with connectors.
  1. Log in to Cloudera Lakehouse Engine instance.
  2. On the Overview page, click the Secret tab.
  3. In the secret list, locate the secret you want to delete.
  4. Click the Delete icon in the Actions column.
    A confirmation dialog box appears warning you about the deletion.
  5. Click Delete.
