Known issues and limitations in Cloudera Lakehouse Engine
Known issues, limitations, and unsupported features for Cloudera Lakehouse Engine 2.0.0 identify impacts on deployment and operational workflows and provide available workarounds.
Known issues in Cloudera Lakehouse Engine
- CLE-763: Queries return unreadable data or fail after Trino inserts into Hive-managed TEXTFILE or JSONFILE tables
When you use Trino to insert data into Hive-created, managed, insert-only transactional tables stored in TEXTFILE or JSONFILE format, the insert can succeed, but subsequent queries from Trino or Hive can return unreadable data or fail. This issue occurs because Trino writes GZIP-compressed data files into transactional delta directories without adding the compression suffix to the filenames. Readers cannot identify the compression format and attempt to read the compressed contents as plain text.
Depending on the file format and query client, you might observe the following symptoms:- Hive queries on TEXTFILE tables return unreadable characters in the first column and NULL values in the remaining columns.
- Trino queries on TEXTFILE tables fail while fetching results, with an error such as Invalid UTF-8 start byte 0x8b.
- Queries on JSONFILE tables fail when reading the files written by Trino.
- CLE-993: Coordinator logs an IllegalArgumentException when a worker stops during queries
- When a Trino worker stops while queries are running, for example
during scale-down, a node drain, or a restart, the coordinator might log an exception
during asynchronous task cleanup.You might observe the following errors in the coordinator logs:
ERROR ... io.trino.server.remotetask.HttpRemoteTask Error in async cleanup on abort ... java.lang.IllegalArgumentException: TaskInfo result did not contain JSON payload; payload= ERROR ... io.airlift.concurrent.BoundedExecutor Task failed
Queries fail only because the worker stopped, not because of these errors. Other queries continue to run normally.
- CLE-836: Reverting a Trino configuration value removes the override and allows subsequent base configuration changes to apply
- When you change a Trino configuration override to match the current base configuration value, the override is removed. The user interface does not indicate that this action removes the override and allows future base configuration changes to apply to Trino. As a result, subsequent changes to the base configuration automatically update the effective Trino configuration value, even if you intended to retain an explicit override.
- CLE-965: Impala queries fail when reading Parquet files written by Trino with unsupported encoding
- Trino 482 enables DELTA_LENGTH_BYTE_ARRAY encoding by
default when writing Parquet files. This encoding is enabled by default for custom
catalogs and for the default harmonycatalog. When Trino writes
data through these catalogs, Impala versions that don't support the encoding can't read
the affected files. Queries fail with an error similar to the
following:
uses an unsupported encoding: DELTA_LENGTH_BYTE_ARRAY
This encoding is disabled by default for the hive-base and iceberg-base catalogs that connect to the base cluster. You need the workaround only when custom catalogs or the harmonycatalog write data that is read by an Impala version that does not support this encoding.
Unsupported features in Cloudera Lakehouse Engine
- CLE-970: Upgrades are not supported for Cloudera Lakehouse Engine in Anywhere Cloud
In the Anywhere Cloud November 2.0 GA release, Cloudera Lakehouse Engine does not support engine upgrades. However, the upgrade button remains visible in the Anywhere Cloud.
