Cluster sizing for Cloudera Lakehouse Engine
Cluster sizing specifies the minimum node counts, compute resources, and storage allocations required to deploy Cloudera Lakehouse Engine.
Node group requirements
The following table lists the minimum node count and the minimum virtual CPU (vCPU), memory, and storage for each node in a node group:
Table 1. Minimum resources per node group
Node group Minimum node count vCPU per node Memory per node Storage per node
Control plane 1 8 16 GB 30 GB
Cloudera Anywhere Cloud core services 3 16 32 GB 120 GB
Cloudera Lakehouse Engine Node 2 16 128 GB 830 GB
Security gateway 1 2 2 GB 30 GB
Use the following guidelines to determine the node count for each node group:
  • The control plane node group requires one node. Cloudera recommends using three nodes for production high availability.
  • The Cloudera Anywhere Cloud core services node group requires three nodes. If you deploy Cloudera Unified Data Fabric and Cloudera Harmony Catalog in the same cluster, use five nodes. Cloudera recommends deploying Cloudera Unified Data Fabric and Cloudera Harmony Catalog before you deploy Cloudera Lakehouse Engine.
  • The Cloudera Lakehouse Engine node group requires one node for each worker and one additional node for the coordinator.
  • The security gateway node group requires one node.
Each coordinator and each worker uses a standard size with a request of 12 CPUs and 114 GiB of memory, and a limit of 14 CPUs and 114 GiB of memory. Every T-shirt size uses a single coordinator without high availability.
T-shirt sizes
The following table lists the worker count and the node count of each node group for each T-shirt size:
Table 2. Node counts by T-shirt size
Size Worker count Control plane node count Cloudera Anywhere Cloud core services node count Cloudera Lakehouse Engine node count Security gateway node count
S 2 1 3 3 1
M 10 3 3 11 1
L 20 3 3 21 1
XL 40 3 3 41 1
The T-shirt sizes support the following use cases:
S
The S size is a proof-of-concept or development configuration with one coordinator and two workers. It is not sized or hardened for production use.
M
The M size is a medium-scale configuration with one coordinator and 10 workers for heavier analytical workloads than the S size supports. It matches the cluster size typically used for TPC-DS benchmark runs at the 1 TB and 10 TB scale factors (SF1000 and SF10000), and suits sustained, concurrent, and data-intensive query workloads.
L
The L size is a large-scale configuration with one coordinator and 20 workers for production-scale analytical workloads with higher concurrency. Compared with the M size, it doubles query parallelism and aggregate memory. Workloads at the TPC-DS 10 TB scale (SF10000) can hold more of the working set in memory and rely less on spill-to-disk.
XL
The XL size is an extra-large configuration with one coordinator and 40 workers for the most demanding analytical workloads, such as data volumes beyond the 10 TB scale, large multi-way joins and aggregations, or many concurrent users and query workloads that share one engine. Compared with the L size, it doubles query parallelism and aggregate memory.
