Choosing and Running a Filter
You can construct a filter, type a filter, or select a suggested or recently run filter.
Do one of the following:
- Select a Suggested or Recently Run Filter: Click the
to the right of the Search button to display a list of sample and recently run filters, and select a filter. The filter text displays in the text box.
- Construct a Filter from the Workload Summary Attributes: Optionally, click
Select Attributes to display
a dialog box where you can chose which attributes to display in the Workload Summary section. Select the
checkbox next to one or more attributes, and click Close.The attributes display in the Workload Summary section along with values or ranges of values that you can filter on. The values and ranges display as links with checkboxes. Select one or more checkboxes to add the range or value to the query. Click a link to run a query on that value or range. For example:
- Type a Filter: Start typing or press Spacebar in the text box.
As you type, filter attributes matching the typed letter display. If you press Spacebar, standard filter attributes display. These suggestions are part of typeahead, which helps build valid queries. For information about the attribute name and supported values for each field, hover over the field in an existing query.
- Select an attribute and press Enter.
- Press Spacebar to display a drop-down list of operators.
- Select an operator and press Enter.
- Specify an attribute value. For attribute values that support typeahead, press the spacebar to display a drop-down list of values and press Enter. Alternatively, you can type a value.
- Click in the text box and press Enter or click Search. The list displays the results that match the specified filter. The Workload Summary section refreshes to show only the values for the selected filter. The filter is added to the Recently Run list.
