Engine configuration: Cloudera Migration Assistant Agent
Lists the two configuration fields of the Cloudera Migration Assistant Agent engine, which runs an agent inside the Anywhere Cloud cluster, connects to a Cloudera Migration Assistant engine instance, and takes its storage setting from that instance.
Configuration fields
Table 1. Cloudera Migration Assistant Agent engine fields
Field Required Default Description
Enable AWC Secret Manager (awcSecretManagerEnabled) No Off Stores the connection credentials of the agent in Anywhere Cloud Secret Service instead of in the internal keystore of the agent. Turn it on only when the Secret Service is set up with an external vault.
Internal Keystore Password (internalKeystorePassword) No Generated The password of the internal TLS keystore of the agent. It is independent of the internal keystore password of the Cloudera Migration Assistant engine, which Cloudera Migration Assistant generates automatically.
Before you turn on Anywhere Cloud Secret Service, ensure that you meet these prerequisites:
  • Your administrator must set up an external vault to use the Secret Management service. For more information, see the External vault requirements for Secret Service documentation.
  • Secret Service is set up with your vault. Until it is, Anywhere Cloud Secret Service rejects requests, and the agent cannot store or read credentials.
For the steps, see Using Anywhere Cloud Secret Service and Vault for agent secrets.
Settings that agents take from Anywhere Cloud
You do not set these values. Anywhere Cloud and the Cloudera Migration Assistant engine provide them:
Table 2. Settings that Anywhere Cloud provides to agents
Setting Value
Cloudera Migration Assistant engine The Cloudera Migration Assistant engine instance that you select when you deploy the agent. Several agents can connect to one Cloudera Migration Assistant engine instance, each in its own namespace.
Agent URL https://[***INSTANCE***].[***CLUSTER-DOMAIN***], where [***INSTANCE***] is the name of the agent instance. You cannot change it.
Storage The agent uses the Use Shared Storage setting of the Cloudera Migration Assistant engine instance.
Anywhere Cloud Console URL Anywhere Cloud sets it, so that the agent can register the console when it starts.
Built-in admin user Cloudera Migration Assistant generates the password of the built-in admin user of the agent, and stores it in the [***INSTANCE***]-agent-admin Secret.
Database Anywhere Cloud deploys a PostgreSQL database for the agent.
Storage purposes and log streams
Bind an S3 bucket to the logs purpose on the Storage tab, with write access, and select the same bucket as the default bucket on the Telemetry tab. Anywhere Cloud writes the logs of the agent in the cma-agent-services and awc-platform log streams. The Engine column of the following table shows which engine writes each log stream:
Table 3. Log streams of Cloudera Migration Assistant
Log stream Engine What it holds
cma-services Cloudera Migration Assistant The logs of the Cloudera Migration Assistant server, the authorization service, and Code Migrator.
cma-platform Cloudera Migration Assistant The logs of the built-in Git server, the web interface server, the documentation search service, and jobs.
cma-agent-services Cloudera Migration Assistant Agent The logs of the agent service.
awc-platform Both The logs of the other pods in the namespace, such as the PostgreSQL database and the service mesh proxy.
The cma-services and cma-agent-services streams are structured JSON. The other streams are plain text. The lifecycle policy of the bucket decides how long Anywhere Cloud keeps the logs.
