Engine configuration: Cloudera Migration Assistant
Defines the configuration fields, validation rules, storage purposes, log streams, passwords, and endpoints of the Cloudera Migration Assistant engine that you deploy on Anywhere Cloud.
Configuration fields
Set these fields in the configuration panel of the Cloudera Migration Assistant engine when you deploy Cloudera Migration Assistant. The following table describes the fields:
| Field | Required | Default | Description |
| Enable LLM (llmEnabled) | No | On | Turns on the LLM connection, and deploys Code Migrator and the documentation search service. When it is off, the LLM fields are ignored, and Code Migrator and the documentation search service are not deployed. |
| LLM Provider (llmProvider) | No | openai |
The type of LLM endpoint. The drop-down list has one option, openai,
which is selected by default. The option stands for any endpoint that is compatible with
the OpenAI API, including Azure OpenAI. |
| LLM Base URL (llmBaseUrl) | When the LLM connection is on | None | The base URL of the LLM endpoint, for example https://api.openai.com/v1 or, for Azure OpenAI, https://resource.openai.azure.com/openai/v1. Must be an http
or https URL. |
| LLM API Key (llmApiKey) | When the LLM connection is on | None | The API key for the LLM endpoint. |
| LLM Model Name (llmModel) | When the LLM connection is on | gpt-5.2-codex |
The name of the model that the endpoint serves. For Azure OpenAI, the name of the Azure deployment. |
| Use Shared Storage (sharedStorageEnabled) | No | Off | Puts the volumes of this instance, and of the agents that connect to it, on the
shared-fs storage class. You cannot change this setting after the
instance is created. |
| CMA Resource Storage Size (cmaResourceStorageSize) | No | 50Gi |
The size of the volume for large Cloudera Data Engineering resources,
in whole GiB, for example 50Gi. Ignored when a bucket is bound to
the cde-resources purpose. |
| Gitea CMA User Password (giteaUserPassword) | No | Generated | The password of the cmaadmin user of the built-in Git server.
At least 8 characters. |
Validation rules
Anywhere Cloud checks the configuration when you deploy the engine, and the deployment fails if a field is not valid. For a list of the error messages, see Cloudera Migration Assistant error reference.
The deploy check verifies only that the base URL is an
http or https URL. If the host, the path, or the API
key is wrong, the error appears later, when Code Migrator calls the LLM. To change the LLM settings later,
see Configuring LLM connection.
Storage purposes
Bind S3 buckets to these purposes on the Storage tab when you deploy the engine:
| Purpose | Required | Access that Cloudera Migration Assistant needs | What it is for |
logs |
Yes | Write | The bucket to which Anywhere Cloud writes the logs of the engine. Select the same bucket as the default bucket on the Telemetry tab. |
cde-resources |
No | Read, list, write, and delete | Large Cloudera Data Engineering resources, such as Spark JAR files, that agents upload during Spark migrations. Without a bucket, the engine keeps them on a volume of the size set in CMA Resource Storage Size. |
You can use the same bucket for both purposes.
Log streams
The Cloudera Migration Assistant components write their logs to standard output. Anywhere Cloud collects the logs and writes them to the bucket that you select on the Telemetry tab. The Engine column of the following table shows which engine writes each log stream:
| Log stream | Engine | What it holds |
cma-services |
Cloudera Migration Assistant | The logs of the Cloudera Migration Assistant server, the authorization service, and Code Migrator. |
cma-platform |
Cloudera Migration Assistant | The logs of the built-in Git server, the web interface server, the documentation search service, and jobs. |
cma-agent-services |
Cloudera Migration Assistant Agent | The logs of the agent service. |
awc-platform |
Both | The logs of the other pods in the namespace, such as the PostgreSQL database and the service mesh proxy. |
The cma-services and cma-agent-services streams are structured JSON. The other streams are plain
text. The lifecycle policy of the bucket decides how long Anywhere Cloud keeps the logs.
See Telemetry and audit logging.
Passwords
Cloudera Migration Assistant generates the internal keystore password automatically. If you leave the Gitea CMA User Password empty, Cloudera Migration Assistant generates that password too. Cloudera Migration Assistant stores all passwords in Kubernetes Secrets, and not in its configuration. See How secrets are stored.
Endpoints
The Cloudera Migration Assistant engine provides these HTTPS endpoints. Replace [***INSTANCE***] with the name of the Cloudera Migration Assistant engine instance, and [***CLUSTER-DOMAIN***] with the domain name of the cluster.
| URL | Used by | Purpose |
https://[***INSTANCE***]-gateway.[***CLUSTER-DOMAIN***] |
Browsers and API clients | The landing page: the web interface and the REST API |
https://[***INSTANCE***]-grpc.[***CLUSTER-DOMAIN***] |
Agents outside the cluster | The connection from an agent to the Cloudera Migration Assistant engine |
https://[***INSTANCE***]-gitea.[***CLUSTER-DOMAIN***] |
Agents outside the cluster, and Git clients | The built-in Git server |
The first endpoint is the landing page of the engine instance. Build it from the name of the instance and the domain of the cluster.
