Datagen connector
The Datagen connector can be used as a source to generate random data. The Datagen connector works out of the box, no mandatory field is required to use the connector. The Datagen connector is useful when you want to experiment and try out SQL Stream Builder or to test your SQL queries using random data.
- Template: datagen
- You do not need to provide any type of information when using the Datagen connector and template.
