Importing a project
You can use a Git repository to import a SQL Stream Builder project that was previously created and exported using source control.
Click Import Project on the
Projects page of Streaming SQL Console.
The Import Project window appears.
Optional: Provide a prefix that overrides the Materialized View table
names.
Provide the Source Settings of the project.
Add a remote Github repository URL to the Clone
URL field.
- To clone without authentication:
https://github.com/cloudera/ssb-examples.git
- To clone and push with HTTP basic authentication
(username/password):
In case of using basic authentication, the personal access token needs to be provided as password. For more information about creating personal access tokens, see the Github documentation.
- To clone and push with SSH authentication (SSH private key):
git@github.com:cloudera/ssb-examples.git
In case of using SSH authentication, you need to generate the private key using the following command:
As not every SSH private key is supported, you can use the following command to convert your key to the acceptable format:ssh-keygen -t ecdsa -b 256 -m pem -C "name@example.com"
ssh-keygen -m pem -p -f [***PATH_TO_PRIVATE_KEY***]
- To clone and push a local git repository on the filesystem of
SSB host:
file:///usr/src/ssb-examples/
- Provide the branch name or tag of the Github repository to the Branch field. This branch is checked out when pulling or pushing to the Github repository.
URL field.
- Provide the name of the project to the Project field.
Enable or disable Allow deletions on import.
- Enable or disable Authentication for the project.
- Click Open to use the created project and start creating SQL jobs.
- Click Switch to open another project than the active one.
- Click Delete to remove the project from SSB.
