System Requirements
Apache Flink support | 1.16.1 | |
Cloudera Runtime component support | ||
7.1.7 | 7.1.8 | |
Kafka1 | 2.5.0 | 3.1.1 |
Schema Registry | 0.10.0 | 0.10.0 |
Streams Messaging Manager | 2.1.0 | 2.3.0 |
HBase | 2.2.3 | 2.4.6 |
HDFS | 3.1.1 | 3.1.1 |
Atlas | 2.1.0 | 2.2.0 |
Kudu | 1.15.0 | 1.15.0 |
Hive | 3.1.3 | 3.1.3 |
Connector support | |
JDBC PostgreSQL | 9.6-12 |
JDBC MySQL | 5.7, 8 |
JDBC Hive | 3.1.3 |
CDC PostgreSQL | 9.6-12 |
CDC MySQL | 5.7, 8 |
CDC Oracle | 19.0.0 |
CDC Db2 | 11.5 |
CDC SQL Server | 2007-2022 |
supported.
