Faker connector
The Faker connector can be used as a source to generate random data. To use the Faker connector, you need to specify the usage The Datagen connector is useful when you want to experiment and try out SQL Stream Builder or to test your SQL queries using random data.
- Template: faker
- You do not need to provide any type of information when using the Datagen connector and template.
