You need an HDFS Home directory to store temporary logs and data of your application to run a Flink job. You must set up the HDFS Home directory for your user to avoid error when using Flink.
To run a Flink job, your HDFS Home directory has to exist. If it does not exist, you
receive an error message similar to the
following:
Permission denied: user=$USER_NAME, access=WRITE, inode=“/user”.
Create HDFS Home directory. Ask your HDFS administrator to perform the
following (or obtain HDFS administrator role).
| Options | Command |
Kerberos enabled |
Kerberos disabled |
In case of an enterprise environment, you can use Hue to set up the Home directory by enabling automatic synchronization for users. For more information, see the Cloudera Runtime documentation.
