System Requirements
Apache Flink support 1.16.2
Cloudera Runtime component support in CDP Private Cloud Base 7.1.9
Atlas 3.0.0
HBase 2.4.17
HDFS 3.1.1
Hive 3.1.3
Kafka1 3.4.1
Kudu 1.17.0
Schema Registry 0.10.0
Streams Messaging Manager 2.3.0
Connector support
JDBC PostgreSQL 9.6-12
JDBC MySQL 5.7, 8
JDBC Hive 3.1.3
CDC PostgreSQL 9.6-12
CDC MySQL 5.7, 8
CDC Oracle 19.0.0
CDC Db2 11.5
CDC SQL Server 2007-2022
Iceberg 1.3.0
1 Connecting to Kafka that is running on remote CDH6 or HDP3 is also supported.
