Some of the connectors have default templates in Streaming SQL Console that allows
        you to create tables with them easily. These predefined templates not only contain the
        CREATE TABLE statement, but every mandatory and optional argument that is needed for the
        table.
              Select SQL Stream Builder from the list of services.
              Click .
          Open a project from the Projects page of Streaming SQL
            Console.
              Select an already existing project from the list by clicking the
                  Open button or Switch button.
              Create a new project by clicking the New Project
                button.
              Import a project by clicking the Import button.
                Click
 next to Jobs from the
                        Explorer.
                Select .
The SQL Editor for the created job opens in a tab.
                Click Templates.
                Select one of the connector templates.
The corresponding CREATE TABLE statement is imported to the
                        SQL Editor.
        After importing the template to the SQL Editor, you need
            to provide the mandatory properties and you can also fill out the optional arguments if
            needed. When you click Execute, the table of the chosen connector
            is created and listed under Virtual Tables.
