Flink DDL
Flink SQL supports Data Definition Language (DDL) statements to create, modify and remove objects within a data structure.
The following table summarizes the supported DDL statements in SQL Stream Builder:
For more information about Flink SQL, see the Apache Flink documentation.
 | DDL | Description | Option |
| CREATE TABLE | Creating table for the SQL query. You can create tables based on the supported connectors. |
| CREATE VIEW | Creating custom views using columns from tables. There is no physical data behind a view. |
| CREATE FUNCTION | Creating User Defined Function (UDF) for a query. |
| DROP TABLE | Deleting a table, view or function. |
| DROP VIEW | ||
| DROP FUNCTIONS | ||
| ALTER TABLE | Modifying table, view or function properties. |
| ALTER VIEW | ||
| ALTER FUNCTION |
