System Requirements
Apache Flink support 1.16.3
CDP Private Cloud Base component support
Cloudera Runtime 7.1.7 SP2
7.1.7 SP3
7.1.9
7.1.9 SP1
Atlas 2.1.0 3.0.0
HBase 2.2.3 2.4.17
HDFS 3.1.1 3.1.1
Hive 3.1.3 3.1.3
Kafka1 2.5.0 3.4.1
Kudu 1.15.0 1.17.0
Schema Registry 0.10.0 0.10.0
Streams Messaging Manager 2.1.0 2.3.0
Connector support
JDBC PostgreSQL 9.6-12
JDBC MySQL 5.7, 8
JDBC Hive 3.1.3
CDC PostgreSQL 9.6-12
CDC MySQL 5.7, 8
CDC Oracle 19.0.0
CDC Db2 11.5
CDC SQL Server 2007-2022
Iceberg 1.3.0
1 Connecting to Kafka that is running on remote CDH6 or HDP3 is also supported.
