Resuming Flink applications
After updating the Cloudera Streaming Analytics artifacts, you can resume your application by the Flink run command. In case you have stopped your application by creating a savepoint, you must add the savepoint location to the command.
Resuming Flink applications without state
  1. Connect to your host where you run your Flink jobs using ssh.
    ssh root@[***FLINK HOSTNAME***]
    Password:[***PASSWORD***]
  2. Submit your Flink application that was stopped before the upgrade.
    flink run [***RUN ARGUMENTS***] \
    [***JAR FILE***] [***APP ARGUMENTS***]
Resuming stateful Flink applications
    -fromSavepoint hdfs:///tmp/savepoints/[***SAVEPOINT NAME***] \
