System Requirements
| Apache Flink support | 1.18.0 |
| Cloudera Runtime component support in CDP Private Cloud Base 7.1.9 SP1 | |
| Atlas | 3.0.0 |
| HBase | 2.4.17 |
| HDFS | 3.1.1 |
| Hive | 3.1.3 |
| Kafka1 | 3.4.1 |
| Kudu | 1.17.0 |
| Schema Registry | 0.10.0 |
| Streams Messaging Manager | 2.3.0 |
| Connector support | |
| JDBC PostgreSQL | 9.6-12 |
| JDBC MySQL | 5.7, 8 |
| JDBC Hive | 3.1.3 |
| CDC PostgreSQL | 9.6-12 |
| CDC MySQL | 5.7, 8 |
| CDC Oracle | 19.0.0 |
| CDC Db2 | 11.5 |
| Apache Iceberg | 1.3.0 |
supported.
