Schema Registry catalog
The Schema Registry catalog allows you to access Kafka topics with registered schemas as Flink SQL tables. You can add Schema Registry as a catalog in Flink SQL by adding the dependency to your project, registering it in Java, and enabling it in the custom environment file.
Each Kafka topic will be mapped to a table with TableSchema that matches the Avro schema.
Maven Dependency
<dependency>
  <artifactId>flink-connector-cloudera-registry</artifactId>
  <version>1.0-csa1.13.0.0</version>
</dependency>
The following example shows how to register and use the Schema Registry catalog from Java:
SchemaRegistryClient client = new SchemaRegistryClient(
	ImmutableMap.of(
		SchemaRegistryClient.Configuration.SCHEMA_REGISTRY_URL.name(),
"http://<your_hostname>:7788/api/v1"
Map<String, String> connectorProps = new Kafka()
		.property(ConsumerConfig.BOOTSTRAP_SERVERS_CONFIG,
                      "<your_hostname>:9092")
		.startFromEarliest()
		.toProperties();
tableEnv.registerCatalog(
   "registry", new ClouderaRegistryCatalog("registry", client, connectorProps)
tableEnv.useCatalog("registry");
