Other supported statements
Beside the supported DDL, DML and SELECT, the supported statements also include DESCRIBE, SHOW and SET that you can use in SQL Stream Builder.
The following table summarizes the supported statements for in SQL Stream Builder:
For more information about Flink SQL, see the Apache Flink documentation.
| Operation | Description |
| DESCRIBE TABLES | Describing the schema of a table |
| SHOW TABLES | Showing a list of existing tables, views, functions, databases or catalogs |
| SHOW VIEWS | |
| SHOW FUNCTIONS | |
| SHOW DATABASES | |
| SHOW CATALOGS | |
| SET | Setting properties of session |
