You can use this Getting Started use case to get familiar with the most simple form
of running a SQL Stream job.
The Getting Started contains the basic steps of running a SQL Stream job. When
executing the job, you do not need to select a sink as the results are displayed in
the browser. SQL Stream Builder provisions a job on your cluster to run the SQL
queries. You can select the Logs tab to review the status of
the SQL job. As data is returned, it shows up in the Results
tab.
