SQL Examples
You can use the SQL examples for frequently used functions, syntax and techniques in SQL Stream Builder (SSB). SSB uses Calcite Compatible SQL, but to include the functionality of Flink you need to customize certain SQL commands.
Metadata commands
-- show all tables SHOW tables; -- describe or show schema for table DESCRIBE payments; DESC payments;
Timestamps, intervals and time
-- eventTimestamp is the Kafka timestamp -- as unix timestamp. Magically added to every schema. SELECT max(eventTimestamp) FROM solar_inputs; -- make it human readable SELECT CAST(max(eventTimestamp) AS varchar) as TS FROM solar_inputs; -- date math with interval SELECT * FROM payments WHERE eventTimestamp > CURRENT_TIMESTAMP-interval '10' second;
Aggregation
-- hourly payment volume SELECT SUM(CAST(amount AS numeric)) AS payment_volume, CAST(TUMBLE_END(eventTimestamp, interval '1' hour) AS varchar) AS ts FROM payments GROUP BY TUMBLE(eventTimestamp, interval '1' hour);
-- detect multiple auths in a short window and -- send to lock account topic/microservice SELECT card, MAX(amount) as theamount, TUMBLE_END(eventTimestamp, interval '5' minute) as ts FROM payments WHERE lat IS NOT NULL AND lon IS NOT NULL GROUP BY card, TUMBLE(eventTimestamp, interval '5' minute) HAVING COUNT(*) > 4 -- >4==fraud
Working with arrays
-- unnest each array element as separate row SELECT b.*, u.* FROM bgp_avro b, UNNEST(b.path) AS u(pathitem)
Union ALL
-- union two different tables SELECT * FROM clickstream WHERE useragent = 'Chrome/62.0.3202.84 Mobile Safari/537.36' UNION ALL SELECT * FROM clickstream WHERE useragent = 'Version/4.0 Chrome/58.0.3029.83 Mobile Safari/537.36'
Math
-- simple math SELECT 42+1 FROM mylogs; -- inline SELECT (amount+10)*upcharge AS total_amount FROM payments WHERE account_type = 'merchant'
-- convert C to F SELECT (temp-32)/1.8 AS temp_fahrenheit FROM reactor_core_sensors;
-- daily miles accumulator, 100:1 -- send to persistent storage microservice -- for upsert of miles tally SELECT card, SUM(amount)/100 AS miles, TUMBLE_END(eventTimestamp, interval '1' day) FROM payments GROUP BY card, TUMBLE(eventTimestamp, interval '1' day);
Joins
-- join multiple streams SELECT o.name, sum(d.clicks), hop_end(r.eventTimestamp, interval '20' second, interval '40' second) FROM click_stream o join orgs r on o.org_id = r.org_id join models d on d.org_id = r.org_id GROUP BY o.name, hop(r.eventTimestamp, interval '20' second, interval '40' second)
-- join with temporal table where LatestRates is a temporal table SELECT o.amount, o.currency, r.rate, o.amount * r.rate FROM Orders AS o JOIN LatestRates FOR SYSTEM_TIME AS OF o.proctime AS r ON r.currency = o.currency
Hyperjoins
Joins are considered "hyperjoins" because SQL Stream Builder has the ability to join
multiple tables in a single query, and because the Kafka table is created from a data
provider, these joins can span multiple clusters/connect strings, but also multiple types of
sources (join Kafka and a database for
instance).
SELECT us_west.user_score+ap_south.user_score FROM kafka_in_zone_us_west us_west FULL OUTER JOIN kafka_in_zone_ap_south ap_south ON us_west.user_id = ap_south.user_id;
Misc SQL tricks
-- concatenation SELECT 'testme_'||name FROM logs;
-- select the datatype of the field SELECT eventTimestamp, TYPEOF(eventTimestamp) as mytype FROM airplanes;
Escaping and quoting
Typical escaping and quoting is supported.
- Nested columns
SELECT foo.`bar` FROM table; -- must quote nested column
- Literals
SELECT "some string literal" FROM mytable; -- a literal
Built In Functions
-- convert EPOCH time to timestamp select EPOCH_TO_TIMESTAMP(1593718981) from ev_sample_fraud; -- convert EPOCH milliseconds to timestamp select EPOCHMILLIS_TO_TIMESTAMP(1593718838150) from ev_sample_fraud;
