System Requirements
Apache Flink support 1.19.1
Cloudera Runtime component support in CDP Private Cloud Base CDP 7.1.9 SP1
Atlas 3.0.0
HBase 2.4.17
HDFS 3.1.1
Hive 3.1.3
Kafka1 3.4.1
Kudu 1.17.0
Schema Registry 0.10.0
Streams Messaging Manager 2.3.0
Apache Iceberg 1.3.0
1 Connecting to Kafka that is running on remote CDH6 or HDP3 is also supported.
Connector support
JDBC PostgreSQL 9.6-16
JDBC MySQL 5.7, 8
JDBC Hive 3.1.3
JDBC Oracle 19, 19c, 21c, 23ai
JDBC Db2 11.5
JDBC SQL Server 2007-2022
CDC PostgreSQL 9.6-16
CDC MySQL 5.7, 8
CDC Oracle 19, 19c, 21c, 23ai
CDC Db2 11.5
CDC SQL Server 2007-2022
