JDBC connector
When using the JDBC connector, you can choose between using a PostgreSQL, MySQL, Oracle, Hive, Db2 or SQL Server databases. Based on the connector type you choose, there are mandatory fields where you must provide the correct information.
Template: jdbc
Using either PostgreSQL, MySQL, Oracle, Hive, Db2 or SQL Server as databases. When you use the JDBC connector, you must specify the JDBC database which are going to be used for the connection.
Type: source/sink
The following fields are mandatory to use the connector:
  • url: The URL of the JDBC database. No default value is specified.
  • table-name: The name of the JDBC table in the database that you need to connect to. No default value is specified.
