System Requirements
| Apache Flink support | 1.19.1 |
| Cloudera Runtime component support in CDP Private Cloud Base CDP 7.1.9 SP1 | |
| Atlas | 3.0.0 |
| HBase | 2.4.17 |
| HDFS | 3.1.1 |
| Hive | 3.1.3 |
| Kafka1 | 3.4.1 |
| Kudu | 1.17.0 |
| Schema Registry | 0.10.0 |
| Streams Messaging Manager | 2.3.0 |
| Apache Iceberg | 1.3.0 |
| Connector support | |
| JDBC PostgreSQL | 9.6-16 |
| JDBC MySQL | 5.7, 8 |
| JDBC Hive | 3.1.3 |
| JDBC Oracle | 19, 19c, 21c, 23c |
| JDBC Db2 | 11.5 |
| JDBC SQL Server | 2007-2022 |
| CDC PostgreSQL | 9.6-16 |
| CDC MySQL | 5.7, 8 |
| CDC Oracle | 19, 19c, 21c, 23c |
| CDC Db2 | 11.5 |
supported.
