The following SQL and Table API features are supported in Cloudera Streaming
    Analytics.
              StreamTableEnvironment (Blink Planner) |
              Catalogs |
                  - DataStream conversions:
                  - Temporary views
                  - SQL update and Query operations
                  - Creating and using catalogs
                  - Listing catalogs, tables, databases and functions
                  - In-memory - Flink default catalog
                  - Hive
                  - Schema Registry
                  - Kudu
              | SQL update statements |
              SQL query statements |
                  CREATE TABLE
                      - Computed columns
                      - Watermark definitions
                      - Table connectors
                          - Kafka
                          - Kudu
                          - Hive (through catalog)
                      - Data formats (Kafka)
                  INSERT INTO
                  - Basic operations
                  - Basic aggregations
                      - Group By
                      - Group By Window
                      - Distinct (only windowed)
                  - Joins
                      - Time-windowed stream-stream join
                  - User defined scalar functions (scalar udf)
