You can create User Defined Functions (UDF) using Java after manually adding the UDF
        function JAR file that contains the UDF class to the Flink connectors. After uploading the
        JAR file on the Streaming SQL Console, you can use the Java UDFs for your SQL
        jobs.
                Create a Java UDF function JAR file.
You can use the following example as a
                    sample:
package udf;
import org.apache.flink.table.functions.ScalarFunction;
public class UdfTest extends ScalarFunction {
   public String eval(String input){
       return "Hello World " + input;
              Select SQL Stream Builder from the list of services.
              Click .
          Open a project from the Projects page of Streaming SQL
            Console.
              Select an already existing project from the list by clicking the
                  Open button or Switch button.
              Create a new project by clicking the New Project
                button.
              Import a project by clicking the Import button.
                Click
 next to Functions.
                Click Upload JAR.
                Click Choose File.
                Search and select the Java UDF function JAR file.
                Click Create.
            The selected JAR file is uploaded, and listed under Functions
                and ready to be used in your SQL queries.
