Products
Solutions
Resources
Support
Community
Homepage
Cloudera Streaming Analytics
1.13.3
(Private Cloud)
Cloudera
Reference Architectures
Cloudera on cloud
Getting Started
Patterns
Preview Features
Data Catalog
Data Engineering
Data Flow
Data Hub
Data Warehouse
Data Warehouse Runtime
Cloudera AI
Management Console
Operational Database
Replication Manager
DataFlow for Data Hub
Runtime
Cloudera on premises
Data Services
Getting Started
Cloudera Manager
Management Console
Replication Manager
Data Catalog
Data Engineering
Data Warehouse
Cloudera AI
Base
Getting Started
Runtime
Upgrade
Storage
Flow Management
Streaming Analytics
Cloudera Manager
Cloudera Manager
Kubernetes Operators
Flow Management Operator
Streaming Analytics Operator
Streams Messaging Operator
Applications
Cloudera Streaming Community Edition
Data Science Workbench
Data Visualization
Edge Management
Observability on premises
Observability SaaS
Third-party Licenses
Flow Management
Topic Filter
Release Notes
What's new in Cloudera Streaming Analytics
Deprecation notices in Cloudera Streaming Analytics 1.13.3
Cloudera SQL Stream Builder
Known issues and limitations
Behavioral changes
Unsupported features
Support Matrix
Component support
System Requirements
Default ports for Flink and Cloudera SQL Stream Builder
Maven dependencies in Flink
Flink API Support
Download
Download location of CSA
Apache Flink Overview
Streaming Analytics in Cloudera
What is Apache Flink?
Core features of Flink
SQL Stream Builder Overview
What is Cloudera SQL Stream Builder?
Key features of Cloudera SQL Stream Builder
Cloudera SQL Stream Builder architecture
Quick Start
Quick Start for Flink
Flink Project Template
Quick Start for Cloudera SQL Stream Builder
Installation & Upgrade
Installation
Deployment scenarios
Cluster service layout with Flink
Cluster service layout with Cloudera SQL Stream Builder
Installing CSD and Parcel
Adding Flink as a Service
Setting the Java executable for the Flink client
Configuring Databases for Cloudera SQL Stream Builder
Setting up MySQL/MariaDB database for Cloudera SQL Stream Builder
Setting up PostgreSQL database for Cloudera SQL Stream Builder
Setting up Oracle database for Cloudera SQL Stream Builder
Adding Cloudera SQL Stream Builder as a Service
Upgrade
Before upgrading your cluster
Stopping Flink applications
Stopping SQL stream jobs
Exporting SQL projects
Upgrading Cloudera Streaming Analytics artifacts and services
After upgrading your cluster
Updating Flink job dependencies
Resuming Flink applications
Importing a project
Resuming SQL jobs
Migration
Migrating Flink service to a different host
Migrating SQL jobs
Security
Securing Apache Flink
Authentication and encryption for Flink
Enabling security for Apache Flink
Configuring custom Kerberos principal for Apache Flink
Enabling SPNEGO authentication for Flink Dashboard
Enabling Knox authentication for Flink Dashboard
Enabling Knox Auto Discovery for Flink
Accessing the Flink Dashboard through Knox
Configuring Ranger policies for Flink
Securing Apache Flink jobs
Using EncryptTool for Flink properties
Securing Cloudera SQL Stream Builder
Authentication in Cloudera SQL Stream Builder
Enabling Kerberos authentication
Configuring custom Kerberos principal for Cloudera SQL Stream Builder
Uploading or unlocking your keytab
Encryption in Cloudera SQL Stream Builder
Enabling TLS for database connection
Configuring Ranger policies for Cloudera SQL Stream Builder
Managing teams in Streaming SQL Console
Using SQL Stream Builder
Getting Started
Projects
Creating a project
Navigating in a project
Managing member of a project
Source control of a project
Masking information before using source control
Setting the environment for a project
Importing a project
Data sources
Adding Kafka Data Source
Adding Catalogs
Connectors
Using connectors with templates
Adding new connectors
Kafka connectors
CDC connectors
JDBC connector
Filesystem connector
Datagen connector
Faker connector
Blackhole connector
Data formats
Adding data formats
Tables
Kafka tables
Configuring Kafka tables
Schema Definition tab
Event Time tab
Data Transformations tab
Properties tab
Deserialization tab
Assigning Kafka keys in streaming queries
Performance & Scalability
Creating Webhook tables
Flink SQL tables
Iceberg tables
SQL jobs
Creating and naming SQL jobs
Running SQL Stream jobs
Configuring SQL job settings
Adjusting logging configuration in Advanced Settings
Configuring YARN queue for SQL jobs
Configuring state backend for Cloudera SQL Stream Builder
Managing session for SQL jobs
Executing SQL jobs in production mode
Functions
Creating Javascript User-defined Functions
Creating Java User-defined functions
Using System Functions
Materialized views
Creating Materialized Views
Configuring Retention Time for Materialized Views
Materialized View Pagination
Using Dynamic Materialized View Endpoints
Configuring Materialized View database information
Using Cloudera SQL Stream Builder with Cloudera Data Visualization
Widgets
Creating widgets
Choosing data sources
Managing data source jobs
Customizing visualization types
Managing widgets on the Dashboard
Notifications
REST API
Monitoring
Collecting diagnostic data
Governance
Flink SQL
Flink DDL
Managing time in Cloudera SQL Stream Builder
Flink DML
Flink Queries
Other supported statements
Data Types
Dynamic SQL Hints
SQL Examples
Data Enrichment
Joining streaming and bounded tables
Example: joining Kafka and Kudu tables
Updating SQL queries with PROCTIME function
Using Apache Flink
Application development
Flink application structure
Source, operator and sink in DataStream API
Flink application example
Testing and validating Flink applications
Configuring Flink applications
Setting parallelism and max parallelism
Configuring Flink application resources
Enabling checkpoints for Flink applications
Configuring PyFlink applications
DataStream connectors
HBase sink with Flink
Kafka with Flink
Schema Registry with Flink
Kafka Metrics Reporter
Kudu with Flink
Iceberg with Flink
File systems
Job lifecycle
Setting up Python for PyFlink
Running a Flink job
Using Flink CLI
Enabling savepoints for Flink applications
Monitoring
Enabling Flink DEBUG logging
Flink Dashboard
Streams Messaging Manager integration
SQL and Table API
SQL and Table API supported features
DataStream API interoperability
Converting DataStreams to Tables
Converting Tables to DataStreams
Supported data types
SQL catalogs for Flink
Hive catalog
Kudu catalog
Schema Registry catalog
SQL connectors for Flink
Kafka connector
Data types for Kafka connector
JSON format
CSV format
Avro format
Supported basic data types
Schema Registry formats
SQL Statements in Flink
CREATE Statements
DROP Statements
ALTER Statements
INSERT Statements
SQL Queries in Flink
Governance
Atlas entities in Flink metadata collection
Creating Atlas entity type definitions for Flink
Verifying metadata collection
Reference
Flink Terminology
Cloudera Flink Tutorials
Storm Flink Migration
Comparing Storm and Flink
Conceptual differences
Differences in architecture
Differences in data distribution
Migrating from Storm to Flink
SQL Stream Builder REST API Reference
Adding Catalogs
Adding data formats
ALTER Statements
Avro format
Behavioral changes
Blackhole connector
CDC connectors
Component support
Connectors
CREATE Statements
Creating a project
Creating widgets
CSV format
Data Enrichment
Data formats
Data sources
Data Types
Datagen connector
Deserialization tab
Download
DROP Statements
Dynamic SQL Hints
Event Time tab
Faker connector
File systems
Flink API Support
Flink Dashboard
Flink DDL
Flink DML
Flink Queries
Flink SQL
Flink SQL tables
Flink Terminology
Functions
Getting Started
Governance
Governance
Hive catalog
Iceberg tables
Iceberg with Flink
Importing a project
Importing a project
INSERT Statements
Installation
JDBC connector
Job lifecycle
JSON format
Kafka connector
Kafka connectors
Kafka tables
Kafka with Flink
Kudu catalog
Kudu with Flink
Materialized views
Migrating SQL jobs
Migration
Monitoring
Monitoring
Notifications
Projects
Properties tab
Quick Start
Reference
Release Notes
REST API
Resuming SQL jobs
Running a Flink job
Security
SQL and Table API
SQL Examples
SQL jobs
Support Matrix
System Requirements
Tables
Upgrade
Using Apache Flink
Using Flink CLI
Widgets
Kafka with Flink
Kudu with Flink
Iceberg with Flink
File systems
Job lifecycle
Running a Flink job
Using Flink CLI
Monitoring
Flink Dashboard
SQL and Table API
Hive catalog
Kudu catalog
Kafka connector
JSON format
CSV format
Avro format
CREATE Statements
DROP Statements
ALTER Statements
INSERT Statements
Governance
Reference
Flink Terminology
Using Apache Flink
offers HBase connector as a sink. Like this you can store the output of a real-time processing application in HBase. You must develop your application defining HBase as sink and add HBase dependency to your project.
Kafka with Flink
offers Kafka connector as a source and a sink to create a complete stream processing architecture with a stream messaging platform. You must develop your application defining Kafka as a source and sink, after adding Kafka dependency to your project.
Kudu with Flink
offers Kudu connector as a sink to create analytical application solutions. Kudu is an analytic data storage manager. When using Kudu with Flink, the analyzed data is stored in Kudu tables as an output to have an analytical view of your streaming application.
Iceberg with Flink
Apache Iceberg is an open, high-performance table format for organizing datasets that can contain petabytes of data. In
, the DataStream API enables you to use Iceberg tables in your Flink jobs.
Feedback
I like something
I have an idea
Something's not working
Can we contact you for follow-up on this?
Back
Submit
OK
1.15
1.15.1
1.15.0
1.14
1.14.1
1.14.0
1.13
1.13.4
1.13.3
1.13.2
1.13.1
1.13.0
1.12.0
1.11
1.11.3
1.11.2
1.11.1
1.11.0
