Using Apache FlinkPDF version
SQL Statements in Flink
You can use the CREATE / ALTER / INSERT / DROP statements to modify objects in the chosen catalog. The statements are executed with the sqlUpdate() method of the TableEnvironment.
StreamTableEnvironment tableEnv = StreamTableEnvironment.create(env, settings);
tableEnv.sqlUpdate("CREATE TABLE t1(c1 STRING) WITH (...)");
tableEnv.sqlUpdate("DROP TABLE t1");
